CUCM INTEGERATION WITH CCX
We have a single cluster in which CUCM,CUC,UCCX,IM version 8.6 installed,when i upgrade only CCX to 10.0 will it be compatible to CUCM or Should i upgrade all the the servers in cluster,,,,advice me on this.
VIP Super Bronze
Sivakalam,No CUCM8.6 is not
Sivakalam,
No CUCM8.6 is not compartible with UCCX 10.
Please check the compartibility matrix here
http://docwiki.cisco.com/wiki/Compatibility_Matrix_for_Unified_CCX
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Ayodeji,So in this case i
Ayodeji,
So in this case i need to upgrade CUCM also to Version 10.0 to suppport.
VIP Super Bronze
Yes, upgrade the whole
Yes, upgrade the whole cluster too..CUCM, CUC, IM and Presence
Ayodeji,Thanks for the info
Ayodeji,
Thanks for the info,
Before upgrading CCX,what are the assesments i need to do since its in production environment,advice me on this.
VIP Super Bronze
 Here is the upgrade guide
Here is the upgrade guide documentation..It will guide you through all you need to do.
NB: Version 10.X of all UC applications UCCX, CUCM, CUCM, IM and P will only run on virtual servers. It wont run on bare metal hardwares. So ensure you have your virtual platform in place
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cust_contact/contact_center/crs/express_10_5/install/guide/UCCX_BK_C2650101_00_cisco-unified-contact-center-express/UCCX_BK_C2650101_00_cisco-unified-contact-center-express_chapter_0100.html
Ayodeji,Its running on
Ayodeji,
Its running on Virtual platform in UCS environment,should i need to purchase a migration license or should i upgrade with PCD? Which is the best way to upgrade all the servers in cluster.
VIP Super Bronze
PCD is cetainly the best way
PCD is cetainly the best way to go. The link below explain in detail how to use PCD.
Go through this link and things should be clearer.
For licenses, look at the license section of th UCCX upgrade guide and for CUCM, you can send your license request to cisco after your upgrade. This link also talk about licenses..
https://www.youtube.com/watch?v=JzG4kz1_hL4
helloAs i know and
hello Ayodeji Okanlawon
As i know and implemented before , PCD can only use for CUCM , and IM&P , and not support UCCX and UC.Is PCD support unity connection , and UCCX now ?. I know the video which shared above , but it only shows upgrade for CUCM and IM&P.Kindly advise , i really need to know , because this will be so great.Kindly find the below link
https://supportforums.cisco.com/blog/12108306/cisco-unified-communication-manager-cucm-10x
VIP Super Bronze
PCD supports all the UC
PCD supports all the UC applications. What varies is the features that you have with them. PCD currently supports upgrade for Unity connection and UCCX but doesnt support migration. (migration is moving from hardware to virtual environment).
Link below shows the list of features supported
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/pcdadmin/10_0_1/CUCM_BK_U9C58CB1_00_pcd-administration-guide-1001/CUCM_BK_U9C58CB1_00_ucmap-administration-guide_chapter_011.html
Hello+5 for you , Thanks alot
Hello
+5 for you , Thanks alot.
100
