CUCM Integration with 3rd party DB
ianwarb
Can anyone tell me if it is possible to integrate CUCM with a 3rd party DB for CTI integration and screen pops using database dips, without using UCCX . I have a customer that wishes to integrate their CUCM with their CRM system from Bullhorn but don't necessarily have a need for UCCX and are working to a budget. Has anyone ever done this with Bullhorn but without deploying UCCX
thanks
Ian
StevenRoot1
Hi Ian,
What was the outcome of this?  We are in a similar situation.  Did CUCM deliver on the Bullhorn customer's requirements?
Steve.
Hi.
You can contact 2Ring guys through www.2ring.com.
They could have a solution for you and they are very smart.
Carlo
Please rate all helpful posts "The more you help the more you learn"
Steven,,,,,did you have any luck?
Ray
rloftus01
I work for a Cisco Partner company that also has a staffing division that uses Bullhorn as our ATS.  Did you succeed in doing any CTI integration with Bullhorn?
Ray
