CUCM Integration with LDAP from Different Companies
We have a Multi tenant scenario is that  10 different companies located in same location and each one is acting as a totally seperate domain (such as cisco.com and microsoft.com) and all need to be integrated with UCM Cluster located in that location, I have some questions regarding that design:
1-Is it applicable to integrate one UCM cluster with seperate different domain companies not located under the same forest (each one is totally seperate that the other one?
2-If yes ,how many LDAP connection can UCM handle (Up to How many domains can be added in UCM)?
3-For corporate directory seach ,How the user can only search his/her related colleague within the same domain and not be seen by other domains (each domain is sperated from the other)?.
Please advise.
Amr Sherif
2 ACCEPTED SOLUTIONS
Hall of Fame Super Silver
Re: CUCM Integration with LDAP from Different Companies
CUCM can support 5 directory integrations, but only one authentication. The workaround is implementation of MSFT ADAM/LDS.
Chris
And youll need to build custom directory scripts to only have users from each domain within it.
java
if this helps, please rate
www.cisco.com/go/pdi
Chris
java
229
