CUCM IP with Microsoft Lync Integration
Hi All,
I am trying to do a configuration for CUCM IPT with Microsoft Lyc Integration.
I have done a dynamic configuration for User connect License as attached.
The deployment requires 2700 new IP Phones to be integrated with 3100 existing Analoge phones.
I used Enhanced Licenses for the 2700 new IP Phones and Essential Licenses for the existing 3100 Analogue Phones.
Please help go through the UCL dynamic config attached to see if all is in place.
Also, for the Lync Integration, is the Cisco UC Integration™  for Microsoft Lync (UCILYNC8.5-K9) neccessary for this integration?
I will appreciate prompt responses. Please help.
Hall of Fame Super Silver
For pre-sales related questions I suggest you reach out to your local Cisco account team or PDI Helpdesk.
HTH,
Chris
We only handle technical questions, that is really a pre-sales question.
You can reach them here:
www.cisco.com/go/ph
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
557
