Community Member
CUCM LDAP integration
Hi All,
how can I force LDAP synch? is there any commnad on CLI? I am using CUCM 7.0.
thanks
Alex
1 ACCEPTED SOLUTION
Re: CUCM LDAP integration
no, once you define the entries when you look at them from ldap directory you get the option to force resync.
if this is the 1st time you define it, complete that step and then go into the entry again after you finish
java
if this helps, please rate
java
www.cisco.com/go/pdi
under ldap directory entry there's the option
java
java
Community Member
thanks for quick response, you mean "perform sync just once" option?
java
java
385
