03-31-2012 05:24 AM - edited 03-16-2019 10:24 AM
Can anyone help me with UCM licensing for CP-3905 IP phones. As I know, only CP-6901 & CP-6911 phones require basic license, all the other IP phones use Enhanced license. Being a SIP phone, what license is required for CP-3905.
Sagar
Solved! Go to Solution.
03-31-2012 06:52 AM
Hi Sagar,
In order to add 3905, you will need "Essential licenses -LIC-CUCM-ESS-A UCL " .
In the link below you can refer to the below mentioned tables.
" Table 4. Device Support for TelePresence, Desktop Video, Enhanced, Basic, and Essential Licenses" and
" Table 3. Telephony and Mobility User Connect Licenses (UCLs)"
Hope this helps.
Please rate helpful posts by clicking on the stars below !!!!
Abdul
03-31-2012 05:32 AM
Hi Sagar,
Please follow the link below.
Licensing
Phone licensing depends on the call-control platform and its policies. For the Cisco Unified Communications Manager, the Cisco Unified SIP Phone 3905 requires appropriate User Connect Licensing (UCL). There are no special license-plus-phone bundles for tier 2 distributors. The phone is not supported on third-party call-control systems.
Hope this helps
-Abdul
Please rate helpful posts!!!
03-31-2012 06:13 AM
Hi Abdul,
Thanks for your quick response. Yes, UCL is required for CP-7905 IP phone & I want to know what kind of UCL (basic or enhanced) is required for this phone when used with CUCM 8.6. Data sheet didn't help me finding the answer.
Sagar
03-31-2012 06:52 AM
Hi Sagar,
Hope this helps.
Abdul
03-31-2012 10:31 AM
Hi Abdul,
Table 4 is exactly what I was looking for. I found the document but didn't spent much time on it. Thanks for pointing them out.
Sagar
