CUCM Login
Dears,
After fresh installation of CUCM i am trying to login in GUI but i couldnt but with the same username and password i am able to login through CLI.
2 ACCEPTED SOLUTIONS
CUCM Login
In this scenario, you cant login to GUI using admin & password and you cant login to CLI using appadmin & password
VIP Purple
CUCM Login
Hi Jack,
You need to do the reverse way.
You need to use admin and password for  OS administration [whether GUI of OS Administration http://x.x.x.x/iptplatform or through CLI]
You need to use appadmin and password for Call Manager Administration page like http://x.x.x.x is ip address of CUCM server.
regds,
aman
Re: CUCM Login
Accounts & Passwords:
Administrator ID & Password - administrator login credentials for the OS
Application ID & Password - These details are used for accessing the GUI for CUCM.
Try the username & Password issued on "Application ID & Password"
For resetting the application password, try the following from the CLI:
"   utils reset_application_ui_administrator_password "
Other Options:
      utils reset_application_ui_administrator_name
      utils reset_ui_administrator_name
      utils reset_ui_administrator_password
VIP Purple
CUCM Login
Hi Jack,
Hope u have configured different Username and password for OS Administration and Application access while installing
CUCM.
Please check.
regds,
aman
CUCM Login
This is CUCM 8.6, uptill now i have installed 6 servers i never face such issue, the username & password for admin which is prompt at the time of installation i am using that for GUI login and it is not accepting, before this it never happenend with me like this.
I am able to login with application username and password which was prompted at the time of installation but not by the admin username and password in GUI
Re: CUCM Login
Hi Jack,
you might be using same user name and password for both OS & GUI which will allow to acess both GUI & OS with the single username and password. If you are using different username & password for OS & GUI, you will not be allowed to login vice versa
CUCM Login
At the time of installation administrator login:
username:admin
password: password
At the time of installation applcation login:
username:appadmin
password: password
Now tellme when i do gui to CUCM IP i use username admin and password password
Is it the  wrong way ???
CUCM Login
CUCM Login
so when login in GUI  i shld use appadmin
and when login in CLI i shld use admin
Is it the best practice to keep the username different??
CUCM Login
admin for OS aadministration & CLI (https://x.x.x.x/cmplatform/showHome.do)
appadmin for GUI app login: https://x.x.x.x/ccmadmin/showHome.do
VIP Purple
CUCM Login
Hi Jack,
regds,
aman
CUCM Login
uptill now i use to put both the same ,, for the first time i put different username and password for them thats why i was confused.
Thanks for both of you for reply +5 for both
VIP Purple
CUCM Login
Hi Jack,
thanks for the rating.
regds,
aman
207
