Community Member
CUCM Logs
I want to know the current logs of CUCM as such of switches and routers we have show logging command which shows us the current logs of any errors,notifications,etc etc Also i want from those logs it should  show me that so and so service has stopped due to some reason.
1 ACCEPTED SOLUTION
You can collect the Audit
You can collect the Audit logs using RTMT to see any configuration changes performed on CUCM and by whom and which IP.
Suresh
It is more convenient to use
It is more convenient to use the RTMT tool to check Logs and Stats in your CUCM server. You can download it under Application > Plugins.
Please rate helpful answers!
Community Member
Dear Amine,I have been
Dear Amine,
I check out with the system logs and post here for any clarifications.
thanks
Community Member
Hello,How can I get the logs
How can I get the logs for different types of user performing different types of configuration changes in the CUCM.
Suresh
Community Member
thanks buddy
thanks buddy
148
