Community Member
CUCM MCS
Hi All,
does anyone knows where I can find summary document regarding number of phones supported per each server and per cluster for different MCS models?
thanks
Alex
1 REPLY
Re: CUCM MCS
yes, the doc everyone should read if involved with CUCM: SRND
Unified CM Platform Capacity Planning
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/6x/callpros.html#wp1043871
if not your versions look for the SRND for the right versions and read the Call Processing section, i'd recommend you to read the whole doc.
java
if this helps, please rate
java
www.cisco.com/go/pdi
112
