CUCM memory utilization
SNMP string is configured on CUCM 8.0. We are able to get CPU utilization report on SNMP but not hard disk utilization.
Is there any configuration required on CUCM to get hard disk (memory) utilization logs to be sent to SNMP? How partition and hard disk (memory) utilization are different from each other?
Anderson
Memory util on UCOS hosts can be monitored using entries in the
HOST-RESOURCES-MIB.  You can download this MIB and find specific OID's using Cisco's SNMP MIB tool.
Some detail on the MIBs to watch here: http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/trouble/8_0_1/tbsnmp.html#wp1105319
Hello Frederick,
Can you assist me in finding the specific OID's please ?
I am looking for the OIDs of the followings:
1-SWAP memory Usage
                Total SWAP memory
2-    Physical memory Usage
                 Total Physical memory
3- SWAP memory Usage
                 SWAP memory  Free
4-     Physical memory Usage
                 Physical memory Free
You can use the RTMT tool.
You can use the RTMT tool. Just log in to the CUCM admin and under the application select plugins the FIND. At the bottom is the RTMT download link and install it. Attach is a screen grab.
1700
