Community Member
CUCM Mig 8.5 to 10.x Node licenses need to be migrated
We're planning to migrate the CUCM Cluster Rls 8.5 with 6 node licenses to a CUCM 10.X. But cannot find the option to include the previously acquired 6 node licenses and be functional on the Rls 10.x Is it necessary to add any SKU in order to has this node licenses migrated? If necessary, which one is the SKU needed. Otherwise, the licenses will be usable after the migration?
Everyone's tags (2)
I don't handle ordering, but
I don't handle ordering, but on 10.x there no longer are any node licenses, you can have as many nodes as you like.
java
if this helps, please rate
www.cisco.com/go/pdi
Community Member
Great Jaime, thks a lot for
Great Jaime, thks a lot for your quickly answer..!!
162
