Community Member
CUCM MOH on SRST
Hi All
i have CUCM deployment with 10 branches, each branch has 2 Voice Gateway (Active/Active from WAN and voice point view) working in SRST, in case of running multicast MoH from flash for both routers, we are limited to have one router muticasting the audio file due to 2 different source doing multicast for same multicast group will make IP phone recieving 2 stream and when it try to play from 2 streamed files the audi will be distored.
in SRST mode with version 8.0 we have 5 files with different Multicast stream, do the enhancment in 8.x fix this issue in standby mode (none SRST)?
Hall of Fame Super Silver
CUCM MOH on SRST
It was added with CME code 8.0, dont recall exact IOS version, here is the section from CME config guide:
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucme/admin/configuration/guide/cmemoh.html#wp1022742
Chris
Community Member
CUCM MOH on SRST
hi chris
when WAN is up can we provide high availability for multicast audio source in 2 routers? as i stated befor during wAN is down SRST mode we can conigure up to 5 MOH files with 5 multicast groups.
245
