CUCM Node License Challenge
Hi All,
I am implementing  CUCM for Publisher and Subscriber node. On the Dynamic Confuguration, I have 2 qty of UCM-7816-80 (which is suppose to take care of the two (Pub and Sub) nodes. But after loading the license, on the license unit report page, the authorized unit in "1" instead of two.
Please what could be the cause? I will appreciate any help.
See the screen shot of the License Unit report Page attached.
1 ACCEPTED SOLUTION
Open the license file, you should see a 2 node licence like this
VENDOR_STRING=2
If there's a 1 in there, that means you only got a 1 node license.
Don't know if this might be related to what you order as I do not handle that, you can reach pre-sales to confirm you really ordered the two node licenses you required.
If you did order the right stuff reach licensing (licensing@cisco.com) with your sales order so they can provide you with the other node license.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
VENDOR_STRING=2
java
java
Hi Javalenc,
Thank you for your response
Re: CUCM Node License Challenge
So What is writed there?  1 or 2 ?
It would be good to inform us.
what is written there is 1
390
