Community Member
CUCM not Synchronised to NTP server
Hi all I have CUCM 7
I used Cisoc OS Administratrtion, Settings>NTP Servers.
and I added the server which is cisco router.
but if ssh the serve and use the command:
utils ntp status , I can find the the server Synchronized for local not for NTP.
ntpd (pid 29169) is running...
     remote           refid      st t when poll reach   delay   offset  jitter
*127.127.1.0     LOCAL(0)        10 l   14   64   77    0.000    0.000   0.002
10.10.10.254    CHU_AUDIO(1)     9 u   21   64   77    0.974  1153882 115118.
synchronised to local net at stratum 11
   time correct to within 199 ms
   polling server every 64 s
Current time in UTC is : Sun Jul 18 03:08:08 UTC 2010
in the router I added the following configuration:
ntp source FastEthernet2/0
ntp master 9
I also tried to change the Stratum number but no luck
any help please and thanks in advanced.
Re: CUCM not Synchronised to NTP server
Is this VMWare or hardware server?
Hailey
Community Member
VMware
I am testing it before doing it in customer site
What version of CUCM and what VMWare product are you using?
I've seen some inconsistencies in syncing with NTP when using VMWare in my lab. I've had one VM build sync with 28XX series router upon build without issue and another fail. However, I had almost no issues syncing to a domain controller (AD)...just tested for the sake of ruling out issues.
Hailey
Please rate helpful posts!
Community Member
I am using CUCM 7.0.1.11000-2
and VMWare Work station 6
thank you for your help
995
