03-06-2012 01:09 PM - edited 03-16-2019 09:58 AM
I just realized that the NTP server our CUCM cluster is pointing to was decomissioned about 8 months ago (it was a 2003 Windows server box). Somehow our phones have maintained accurate time???
I need to update the NTP server and I think I found where to do it, though I want to make sure its not going to have adverse effects on the system and phones?
Any help?
CUCM 7.1.3b
thanks
Solved! Go to Solution.
03-06-2012 04:07 PM
Luke,
This is the same OS Admin UID & password from the CUCM admin page
If you are on the web page for CUCM Admin in the top
right there is a drop down
CM Admin
Reporting
Serviceability
OS Admin
Alex
03-06-2012 01:31 PM
Luke
You can change the NTP server on the OS admin pages
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/cucos/7_1_2/cucos/iptpch4.html#wp1042131
This will propogate a time change on your phones.
If your existing server reference is offline your CUCM will be using
the onboard system clock from the physical server
Alex
03-06-2012 01:33 PM
so in theory, if the time is right already, there should really bo no noticeable change?
03-06-2012 01:42 PM
Luke
You can check your current ntp status by using the
Putty SSH console
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/cli_ref/7_1_2/cli_ref_712.html#wp42375
utils ntp status
and change here to with
utils ntp configure A.B.C.D
No noticeable affect
Alex
03-06-2012 02:28 PM
thanks, im embarrassed but I cant figure out what username and password to use to SSH into the box? I tried all of the different Call manager log and passes, any ideas which one is used to SSH?
thanks
03-06-2012 04:07 PM
Luke,
CM Admin
Reporting
Serviceability
OS Admin
Alex
