CUCM Operating System Administrator Password Recovery
Hi to all
I have followed this procedure but i have stucked when i put the cd/dvd..I put an empty cd/dvd but is not moving forward
https://supportforums.cisco.com/docs/DOC-15800
It asked for a media cd/dvd
could you pls give some lights?
cc
Please rate all useful posts Regards Chrysostomos ""The Most Successful People Are Those Who Are Good At Plan B""
1 ACCEPTED SOLUTION
Super Bronze
Re: CUCM Operating System Administrator Password Recovery
I think it's any CD that can be mounted - you're proving that you have physical access to the box, not that you have a disc you can rebuild the server from. I think your problem is that you have used a blank that can't be 'read'.
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Blank CD/DVD wont do, you will have to use any one of the DVD which comes with the CUCM installation kit ( e.g. use CUCM installation DVD ). This step is required to verify if you have inserted original Cisco media/dvd.
GP.
Pls rate helpful posts !!
Thank you for the answer. Now the cucm has 6.x version.. I have to put the 6.x version cd or any version will be ok.. I need installation cd/dvd or recovery disk..
Chrysostomos
Sent from my iPhone
As I remember, any DVD which came with the kit should do.
GP.
Super Bronze
Aaron
Hi to all
thank you for the reply
Problem solved ..Finally aaron had right
cc
436
