aod
Community Member
CUCM Phone Firmware
Is there a way to run a report to discover which phone may not be running
the default firmware.
Hall of Fame Super Gold
Re: CUCM Phone Firmware
How many switches you have? The simples thing can be "show cdp neigh detail | inc port | SW" on the switch.
Not the exact string, but you got the idea.
Community Member
  1. Choose Device > Device Settings > Firmware Load Information.
The page updates to display a list of device types that require firmware loads. For each device type, the Devices Not Using Default Load column links to configuration settings for any devices that use a non-default load.
430
