Community Member
CUCM phone state unknown
In cucm 8.6(2), when I see the state of a phone as unknown that used to be registered to the CUCM but has been disconnected, how long from the time of disconnect until the phone shows as unknown?  Is there a timer or is it a reboot of a system, etc?  We are trying clean up abandon entries in the CUCM and do not want to delete a phone of someone that is on vacation, medical leave or any other reason the phone may be off but still should be kept on the system.
Terry
Everyone's tags (4)
2 ACCEPTED SOLUTIONS
VIP Red
A phone will become "unknown" fairly instantaneously, it is definitely NOT reboot dependent.
To answer you question specifically, there is no quick and easy way to find out if users have unplugged their phone becuase they are on hoiliday, there is no such thing. My question would be why would you?
What I would do is change the MAC addresses of these phones that are unknow, and give them a meaningfull description (such as the real MAC address and desknumber). by all means do not remove them from the system, so that is someone reports their phone is not registered, you can reinstate it easily by changing the dummy back.
That way you can leave the dummy addresses in CUCM for a certain period of time, before permanently deleting them.
Otherwise I cant see a fiull proof way.
Please remember to rate useful posts, by clicking on the stars below.
Hello Terry
Check this thread
https://supportforums.cisco.com/message/1069035#1069035
Br,
Nadeem
Please rate all useful post.
Br, Nadeem Please rate all useful post.
VIP Red
Hello Terry
Check this thread
Br,
Nadeem
Community Member
This is a great suggestion by minkdennis.  Thank you.
Community Member
By default, this is 3 days.
It is controlled by a Cisco RIS Data Collector service parameter called RIS Unused Cisco Callmanager Device Store Period. This parameter specifies the RIS database information storage period for any unregistered or rejected device information from the Cisco CallManager service. After the time specified in this parameter expires, Cisco CallManager removes the expired entries during the next RIS database cleanup time (specified in the RIS Cleanup Time of the Day parameter). it has a minimum value of 1 day and a maximum value of 30 days.
Johan
2867
