tka
CUCM primary server config in Unity Connection
Hi All,
What happen when the specified primary CUCM server ( whose address is specified in the configu of the UC) falls down ? how could UC knows about the other Callmanager in the cluster ?
bes tregards,
Re: CUCM primary server config in Unity Connection
is this standalone CUC or CUCMBE???
CUC needs you to define the servers in the integration, CUCMBE is all in one box solution and failover is not available
java
if this helps, please rate
java
www.cisco.com/go/pdi
tka
thanks !
227
