CUCM R8.0 and SRST issues
I have the following situation, one central office and tree remote offices each one have a 2911 as SRST, the 2911 also have FXO and FXS ports for analog internal users and analog trunks.
When the data link with central Office it´s lost, all the IP phones register on SRST device and can call each other, even they can call the FXS users and made external call to PSTN.
So maybe you are wondering which are the issues? at first eventhoug that on SRST mode a could made external call to PSTN, when there are external inbound calls to our systems, the call rings once and then nothing happen, nor ringing signal on the assitants IP phone. And the FXO port stay on busy stated.
Second when we tried to made a call from a FXS users, picking up the handset on the analog phone, and we didn't hear any dial tone, nor we could dial any DN.
Any Ideas?
Luis Martinez
1 ACCEPTED SOLUTION
Try this
Configure the following commads and this should work -
application
global
  service alterenate default
ccm-manager fallback-mgcp
dial-peer voice 123 pots
destination-pattern
port
And take look on this documentation:
http://www.cisco.com/en/US/tech/tk1077/technologies_tech_note09186a0080144630.shtml#prob1
Rate this if helps you
Happy new year
Green
Hi Luis
Under normal working is the SRST gateway H323 or MGCP
Can you post the SRST gateway config
Alex
Regards, Alex. Please rate useful posts.
Alex,
The SRST device in normal working it's MGCP, below you will find the sh run
RT2911VCBB01#sh run
Building configuration...
Current configuration : 14456 bytes
! Last configuration change at 09:46:49 BO Wed Dec 28 2011 by dima
! NVRAM config last updated at 11:01:53 BO Wed Dec 28 2011 by dima
version 15.1
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
hostname RT2911VCBB01
boot-start-marker
boot-end-marker
logging buffered 4096000
aaa new-model
aaa authentication login vty group tacacs+ local
aaa authorization exec default group tacacs+ if-authenticated
aaa authorization commands 1 default group tacacs+ if-authenticated
aaa authorization commands 15 default group tacacs+ if-authenticated
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 1 default start-stop group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
aaa session-id common
clock timezone BO -4 0
no ipv6 cef
ip source-route
ip cef
voice-card 0
dspfarm
dsp services dspfarm
voice class custom-cptone ENTEL
dualtone disconnect
  frequency 427
  cadence 202 195
voice class custom-cptone COMTECO
dualtone disconnect
  frequency 427
  cadence 500 497
voice class custom-cptone Telular
dualtone disconnect
  frequency 427
  cadence 529 490
application
global
  service alternate Default
license udi pid CISCO2911/K9 sn FTX1523AJ5A
hw-module pvdm 0/0
redundancy
ip ssh version 2
interface GigabitEthernet0/0
description "ENLACE TRONCAL SW2948VCBBA01"
no ip address
duplex auto
speed auto
interface GigabitEthernet0/0.2019
description "GATEWAY DE DATOS"
encapsulation dot1Q 2019
ip address 172.20.192.254 255.255.255.0
ip helper-address 172.20.192.1
interface GigabitEthernet0/0.2119
description "GATEWAY DE VOZ"
encapsulation dot1Q 2119
ip address 172.21.192.252 255.255.255.0
interface GigabitEthernet0/1
description "ENLACE ROUTER ENTEL"
ip address 10.10.10.2 255.255.255.252
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip route 0.0.0.0 0.0.0.0 10.10.10.1
logging trap warnings
logging 172.20.197.231
control-plane
voice-port 0/0/0
supervisory disconnect dualtone mid-call
supervisory custom-cptone COMTECO
no battery-reversal
echo-cancel coverage 64
cptone CO
timeouts call-disconnect 3
timeouts wait-release 3
timing hookflash-out 50
connection plar opx 6130
description "Linea 44762179"
voice-port 0/0/1
no battery-reversal
cptone CO
description "Linea 44762497-P"
voice-port 0/0/2
no battery-reversal
cptone CO
description "Linea 44762499"
voice-port 0/0/3
no battery-reversal
cptone CO
connection plar opx 6139
description "Linea 44762498 - FAX"
voice-port 0/1/0
supervisory custom-cptone ENTEL
no battery-reversal
cptone CO
description "ENTEL - 44117371"
voice-port 0/1/1
no battery-reversal
cptone CO
description "ENTEL - 44117372"
voice-port 0/1/2
no battery-reversal
cptone CO
connection plar opx 6129
description "ENTEL - 44117373 - FAX"
voice-port 0/1/3
supervisory custom-cptone Telular
no battery-reversal
cptone CO
description "Telular 67598569"
voice-port 0/2/0
cptone CO
voice-port 0/2/1
cptone CO
voice-port 0/2/2
voice-port 0/2/3
cptone CO
ccm-manager redundant-host trscccm01
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server 172.21.200.10 172.21.200.40
ccm-manager config
mgcp
mgcp call-agent trscccm02 2427 service-type mgcp version 0.1
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp profile default
sccp local GigabitEthernet0/0.2119
sccp ccm 172.21.200.40 identifier 1 version 7.0
sccp ccm 172.21.200.10 identifier 2 version 7.0
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate ccm 2 priority 2
associate profile 1 register RT2911VCBB01-CF
sccp ccm group 2
associate profile 2 register RT2911VCBB01-XC
dspfarm profile 2 transcode universal
description "3 sesiones de Xcode"
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
maximum sessions 3
associate application SCCP
dspfarm profile 1 conference
description "son 2 conferencias de 8 participantes"
codec g711ulaw
codec g729r8
codec g729ar8
codec g729abr8
codec g711alaw
maximum sessions 2
dial-peer voice 999000 pots
service mgcpapp
port 0/0/0
dial-peer voice 999001 pots
service mgcpapp
port 0/0/1
dial-peer voice 999002 pots
service mgcpapp
port 0/0/2
dial-peer voice 999003 pots
service mgcpapp
port 0/0/3
dial-peer voice 999010 pots
service mgcpapp
port 0/1/0
dial-peer voice 999011 pots
service mgcpapp
port 0/1/1
dial-peer voice 999012 pots
service mgcpapp
port 0/1/2
dial-peer voice 999013 pots
service mgcpapp
port 0/1/3
dial-peer voice 999020 pots
service mgcpapp
port 0/2/0
dial-peer voice 999021 pots
service mgcpapp
port 0/2/1
dial-peer voice 999023 pots
service mgcpapp
port 0/2/3
dial-peer voice 996129 pots
description "interno 6129"
destination-pattern 6129
port 0/2/0
forward-digits all
dial-peer voice 996134 pots
description "interno 6134"
destination-pattern 6134
port 0/2/1
forward-digits all
dial-peer voice 996139 pots
description "interno 6139"
destination-pattern 6139
port 0/2/3
forward-digits all
dial-peer voice 999900 pots
description "llamada local 1XX"
preference 1
destination-pattern 91..
port 0/0/0
prefix 1
dial-peer voice 999901 pots
preference 2
port 0/0/1
prefix 1
dial-peer voice 999902 pots
preference 3
port 0/0/2
prefix 1
dial-peer voice 999903 pots
description "llamada local 4XXXXXX"
preference 1
destination-pattern 94......
port 0/0/0
prefix 4
dial-peer voice 999904 pots
preference 2
port 0/0/1
prefix 4
dial-peer voice 999905 pots
preference 3
port 0/0/2
prefix 4
dial-peer voice 999906 pots
description "llamada celular 6XXXXXXX"
destination-pattern 96.......
port 0/1/3
prefix 6
dial-peer voice 999907 pots
description "llamada celular 7XXXXXXX"
destination-pattern 97.......
port 0/1/3
prefix 7
dial-peer voice 999908 pots
description "llamadas a 800XXXXXX"
preference 1
destination-pattern 9800......
port 0/1/0
prefix 800
dial-peer voice 999909 pots
preference 2
port 0/1/1
prefix 800
dial-peer voice 9999010 pots
preference 3
port 0/1/2
prefix 800
dial-peer voice 999911 pots
description "llamada 90XXXXXXX"
preference 1
destination-pattern 990.......
port 0/1/0
prefix 90
dial-peer voice 999912 pots
preference 2
port 0/1/1
prefix 90
dial-peer voice 999913 pots
preference 3
port 0/1/2
prefix 90
dial-peer voice 999914 pots
description "llamada LDN"
preference 1
destination-pattern 90........
port 0/1/0
prefix 010
dial-peer voice 999915 pots
preference 2
port 0/1/1
prefix 010
dial-peer voice 999916 pots
preference 3
port 0/1/2
prefix 010
dial-peer voice 999917 pots
description "llamadas LDI"
preference 1
destination-pattern 900T
port 0/1/0
prefix 0010
dial-peer voice 999918 pots
preference 2
port 0/1/1
prefix 0010
dial-peer voice 999919 pots
preference 3
port 0/1/2
prefix 0010
gatekeeper
shutdown
call-manager-fallback
max-conferences 8 gain -6
transfer-system full-consult
ip source-address 172.21.192.252 port 2000
max-ephones 25
max-dn 25
system message primary SRST Fallback Active
system message secondary SRST Fallback
end
Any help or idea will be very grateful.
Luis Martinez
Try this
application
global
destination-pattern
port
Happy new year
Hi Leonardotadeu,
I already had this lines on my configuration
application
global
I didn't have this: " ccm-manager fallback-mgcp" I wil put on the configuration, tested and see what happen.
Could you explain what would do the dial-peer voice 123 pots configuration?
Luis Martinez
Silver
Please see this link it might help:
http://www.cisco.com/en/US/tech/tk652/tk653/technologies_tech_note09186a00800ae2d1.shtml
also insert (service mgcpapp) into the dial peers
Posted by WebUser Mohamed Libya
Hi Mohamed Libya,
Thanks for the link, I used the disconect tone configuration to solutions this issue "when there are external inbound calls to our systems, the call rings  once and then nothing happen, nor ringing signal on the assitants IP  phone. And the FXO port stay on busy stated." Now the FXO port after put in busy stated get free a few seconds later.
Inserting the "service mgcpapp" on the dial peers witch of the following issues will be solve?
a) That the incoming call on FXO ports are not ringing on the IP phone of the secretary
b) When we tried to made a call from a FXS users, picking up the  handset on the analog phone, and we didn't hear any dial tone, nor we  could dial any DN.
Luis Martinez
614
