CUCM Remote Destination Profiles - Untick Box
We have deployed RDPs and by default the box item "Use Device Pool Calling Part Transformation CSS"  is Ticked. I would like to know if there is a way to configure the system so that the default setting will be Unticked and future RDPs will be configured accordingly, and also if there is a away to Bulk assign this value to Unticked for existing RDPs. I tried using BAT but it seems that this box is not supported. Perhaps a CLI SQL command?
hi ,
The default is to have it checked and is as per design.  What exactly are you trying to achieve by having it unchecked in the default setting?
To use the Calling Party Transformation CSS that is configured in the device pool that is assigned to this device, check this check box. If you do not check this check box, the device uses the Calling Party Transformation CSS that you configured in the Remote Destination Profile Configuration window.
Karthik
Re: CUCM Remote Destination Profiles - Untick Box
You can creat RDP template and use it to bulk add.
go to 'bulk Admin', 'Mobility', 'RDP', 'RDP Template' , then Add new.
Then use RDP insert.
Ali
500
