Community Member
CUCM RNA Checkbox and Destination
So just a check question. If you have both the checkbox to go to VM. And a destination to forward to on a DN. Which would take priority? I'm assuming would go to voicemail would be the priority. But we are actually seeing a mismatch. Sometimes goes to VM sometimes forwards to the destination.
1 REPLY
VM should always take precedence when checked
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
101
