CUCM seconds fails
How time the phone wait the change to secondary CUCM ?
Example:
Phone A is registered in the CUCMA.
The CUCMA is not availble.
Phone B is registered in the Secondary CUCM, called CUCMB.
How many is the time in seconds that the phone wait response for its primary server?
1 REPLY
Re: CUCM seconds fails
I'm assuming the question is "How much time..." right?
The default keepalives are 30 seconds to primary, 60 seconds to secondary.
A phone loses 3 keepalives before failing over to a secondary, it keeps trying with the primary for the time it comes back
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
101
