CUCM Secure Mode
HI All,
I have been asked if my CUCM is in Secure Mode or not, I can not find on the CUCM where this Reference is, does anybody have any idea's what this could be?
Nathan
Everyone's tags (3)
1 ACCEPTED SOLUTION
CUCM Secure Mode
Enterprise parameters.
This parameter indicates the security mode of the cluster. A value of  0 indicates Non Secure (phones will register in non-secure mode [no  security]); 1 indicates Mixed (the cluster allows the registration of  both secure devices and non-secure devices). Because this parameter is  read-only, to change the cluster security mode, you must run the CTL  Client plugin. Note: You must restart Cisco CallManager for the  parameter change to take effect.
   This is a required field.
   Default:                  0
   :                Restart Cisco CallManager service for the parameter change to take  effect.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
1 REPLY
CUCM Secure Mode
   Default:                  0
java
java
2425
