CUCM Server suggestions
which MCS would you suggest for a maximum 250 users? I think MCS-7816
which MCS would you suggest for a maximunm 500 users? I think MC-7825
which CUCM version would you suggest 7.0 or 7.1?
also I need a minimum cost E1 gateway fully working with minimal or no scalability, I'm thinking about 2811V + an added PVDM2-16
I thank you all for your suggestions
Johnny
Re: CUCM Server suggestions
If you are looking for Cisco approved ranges then I recommend going to the SRND.  If you are looking for opinions, I never deploy anything lower than a MCS-7825 myself.  My reasoning is not really founded in the black and white area of technical specifications.  I just think of the MCS-781x as lab play toys.
CUCM version:  I would go with 7.1(3b)SU2.  I have been running that in my lab and at a few customer sites without issue.
Gateway.  Your choice.  I like to stay aware from anything lower than a 28xx.  I also recommend provisioning adequate DSPs for conferencing resources.
When you look at your numbers, at 15 - 25% growth factor and see how that makes you feel.
HTH.
Bill
Please remember to rate helpful posts.
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
Hall of Fame Super Red
Hi Johnny,
Just to add one quick note to the always great tips from Bill (+5 Bill)
For a full E1 (30 B-Channels) you would need  one PVDM2-32 or two PVDM2-16
Cheers!
Rob
So would you use a 7825 for both 250 and 500 users, or 7825 for 250 users and
greater for 500 users?
If I have a 2811 with a PVDM2-16 i need to add only PVDM2-16 for a full PRI or PVDM2-32?
171
