CUCM set web-security syntax
Erik Peterson
Level 4
Level 4
I'm looking to modify parameters used for signing cert request on a CUCM 6.1.1 installation. The customer's O would ideally be a multi-word value (e.g. Acme Inc.), but the CLI syntax would not appear to support that. Can I include the desired phrase in quotes, or other formatting in order to make this happen?
rtapiawala
Try
set web-security "OU Name" "O Name" "Location" "City" "Country"
It should work.
I hope this helps.
