Community Member
CUCM SIP Route Pattern Discussion
1 ACCEPTED SOLUTION
To any system to which you
To any system to which you can route SIP calls, audio and/or video, like a VCS.
Or if you have another PBX which register endpoints with URIs and accepts SIP trunks, you could also use it.
java
if this helps, please rate
www.cisco.com/go/pdi
Help -> For this pageIPv4
IPv4 Pattern
(Required) Enter the domain, sub-domain, IPv4 address, or IP subnetwork address.
For Domain Routing pattern usage, enter a domain name IPv4 Pattern field that can resolve to an IPv4 address. The domain name can contain the following characters: [, -, ., 0-9, A-Z, a-z, *, and ].
For IP Address Routing pattern usage, enter an IPv4 address the IPv4 Pattern field that follows the format X.X.X.X, where X represents a number between 0 and 255.
For the IP subnetwork address, in Classless Inter-Domain Routing (CIDR) notation, X.X.X.X/Y; where Y is the network prefix that denotes the number of bits in the address that will be the network address.
Tip
If the SIP trunk supports IPv6 or both IPv4 and IPv6 (dual-stack mode), configure the IPv6 Pattern in addition to the IPv4 pattern.
java
Community Member
Could you please highlight
Could you please highlight the answer?
I have read some Cisco documentation and CUCM help before posting my question, and i did not find a way to create a SIP route pattern that could match any IP address.
java
Community Member
Thank you and +5but I did not
Thank you and +5
but I did not find the solution, to make my question more clear, I have a customer they used CUCM only for video conference endpoints, no any IP phone. They want to call by IP address so I want to create only one route pattern to accept all IP addresses, so how I should create this route pattern. This route pattern should accept any real IP address
You cannot create one pattern
You cannot create one pattern for all IPs, the field only accepts from 0 to 255, meaning, it HAS to be a perfectly defined IP. If you could do that, if would mention what to use for wildcards, don't you think???
java
Community Member
When I read in the
When I read in the documentation I said it is not possible to implement but I asked to see if there is any work around solution
By the way, where I can use SIP route pattern other than video conference
java
Community Member
Community Member
Jaime, does Cisco have plans
Jaime, does Cisco have plans to enable wildcards in this field?
Roadmap questions have to be
Roadmap questions have to be addressed by your AM, or posted in partner communities, this cannot be discussed at CSC.
java
Community Member
Gotcha.  Thanks.
Gotcha.  Thanks.
CUCM won't allow you to do a
CUCM won't allow you to do a summarized 0.0.0.0/0 Route Pattern.
But you can accomplish this in two SIP Route Patterns:
1.0.0.0/1 (this will cover 0.0.0.0 - 127.255.255.255)
and
128.0.0.0/1 (this will cover 128.0.0.0 - 255.255.255.255)
-Tony
Please remember to rate useful posts.
Community Member
This is what I call an answer
This is what I call an answer. Thank you man.
-- Filippo Zangheri Gencom S.r.l.
Community Member
Saved my bacon, thanks!
2934
