CUCM-SME queries
I'm reading for SME and I have few queries:
- Will the SME act as SAF forwarder? or will we need IOS Forwarder? for both between leaf & SME and SME's clusters.
- What is the configuration for SAF/CCD for leaf and SME? What is the SIP trunk Type? Will be CCD? what about H.323?
- For old CUCM, what is the Trunk types? will you need to update the CUCM for the Trunk Type?
- Do you have an example or Best practice for SME?
- What is the CME configuration?
Thanks .....
1 REPLY
Hi Nadernoshy,Did you get
Hi Nadernoshy,
Did you get answer of your questions & did you manage CUCM-SME deployment ?
I have CUCM-SME installation nearby. My all CUCM leaf clusters are 8.6.
As SRND suggested i am planning to use SIP trunk between leaf & SME.
how to configure inbound & outbound calls in SME ? what parameter should i use to configure inbound ? e.g. should i use translation-pattern for incoming call ? how can i perform digit manipulation in SME to break 8 digits (in inbound call) into 4 digit extension ?
153
