CUCM Speed Dial
clark white
Level 2
Level 2
  • My manager want to call his 5 no's of coworkers by one press button, just like a speed dial, but he has only 2 line phone, How can i configure for other 4 Nos coworkers,
  • How i can configure a personal Directory for the manager, any explanation link or video.
3 Accepted Solutions
Hi Clark,
I agree with my friend Carlo here (+5 )
So my first thought would be to upgrade the manager phone to a
model that has more line buttons and can support a really easy 5
speed-dial buttons with labels etc. But managers hate to spend money $$
and they are generally unreasonable to boot so we'll look at plan B
You can use Abbreviated Dials (as Carlo nicely noted) that do not use a Line Button
The  Speed Dials that are configured by the User via ccmuser are associated  with spare Line Buttons (if any are available)and the remainder are  accessed via the AbbrDial Softkey (Abbreviated Dial)
In  this test scenario the 7962 has a Button Template called 3-Line  3-Speeddial so the first 3 that are setup via ccmuser take Line Button  4,5 and 6. The remainder are accessed by keeping the Handset On-Hook,  dialing the applicable Speed Dial Code (for example 5 followed by  pressing the AbbrDial Softkey) the number programmed against Speed Dial 5 will then be called;
The following options are available for SEP00170EEE2F88 (Test Q335):
Forward all calls to a different number
Add/Update your Speed Dials
Configure your Cisco IP Phone Services
Configure your Cisco Personal Address Book
Change the Message Waiting Lamp policy for your phone
Change the Ring Settings for your phone
Change the Locale for this phone
Change the Locale for these web pages
Change your Password
Change your PIN
Add/Update Your Speed Dials
Configure the Speed Dial Buttons for your Cisco 7961 (SEP00170EEE2F88)
Use  this page to enter the phone numbers you want associated with each of  your Speed Dial buttons. When you are done, click Update.
You'll like want to fire this up as well to appease the manager
Off-Hook Abbreviated Dialing
Cisco   Unified Communications Manager release 7.1(2) (firmware 8.5(2))   introduces Off-Hook Abbreviated Dialing. The user can initiate Off-Hook   Abbreviated Dialing while conferencing a call, while transferring a   call, or while placing a new call after putting a call on hold.
Note   The phone must be assigned a softkey set that includes the AbbrDial   softkey before it can be used. The softkey can be assigned by using the   Softkey Template Configuration for the following states-Offhook,  Offhook  with Feature, and Digits After First.
The following Cisco Unified IP Phones (SCCP and SIP) support Off-Hook Abbreviated Dialing:
Cisco Unified IP Phone 7975G
Cisco Unified IP Phone 7971G-GE
Cisco Unified IP Phone 7970G
Cisco Unified IP Phone 7965G
Cisco Unified IP Phone 7962G
Cisco Unified IP Phone 7961G
Cisco Unified IP Phone 7961G-GE
Cisco Unified IP Phone 7945G
Cisco Unified IP Phone 7942G
Cisco Unified IP Phone 7941G
Cisco Unified IP Phone 7941G-GE
Cisco Unified IP Phone 7931G
Cisco Unified IP Phone 7911G
Cisco Unified IP Phone 7906G
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/firmware/8_5_2/english/release/notes/7900_852.html#wp158457
Cheers!
Rob
"May your heart always be joyful
And may your song always be sung
May you stay forever young "
- Dylan
Hi Clark,
please follow the steps:
a. first go off-hook . you would hear a dial tone.
b. now, press AbbrDial SoftKey and would hear zip like tone.
c. now , you need to enter the speed dial code which could be 1, 2 , 3 as circled in attached snapshot
d. After this press AbbrDial SoftKey a second time.
e.finally, the number corresponding to speed-dial code is dialed.
regds,
aman
Hi.
You can also dial the abbreviate dial number, without going offhook, just press the abbreviated dial numer as Aman suggested and press AbbrDial softkey.
The phone will then activate the speakerphone dialing the number defined on that Abbreviated dial ID.
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
12 Replies 12
Hi Clark.
As alternative to Speed dial, you can consider Abbreviated Dialing option.
You can configure them on Speed Dial section of phone configuration Page.
What he should do is press the number of configured Abbreviated dial number and press AbbrDial softkey on the phone
For personal address book, you can use the personal address book.
Carlo
Hi Clark,
Change your PIN
Cheers!
Rob
- Dylan
Hey My Friend!
Your anwsers are always so detailed that I feel like a child at school when I read them
Although someone could have a different thought, this community is really great and not only for the amazing knowledge of the attending people, but for the passion on helping others that people like you put every day.
+5 all life long
Cheers
Carlo
Hey Carlo,
Thank you for your very kind words my friend! WOW
The strength of the Community comes from the participation
of all it's members, it's really a sum of all its parts so to speak.
I think the reason we all stick around is due to the kind nature of
the people here and you are a perfect example of that!
Thanks again, you certainly made my day!
Cheers!
Rob
- Dylan
Dea Experts,
Please find the attached,It is not working with me.
Steps i followed.
configured the desire numbers for speed dial for example 5511 as per the attached
configured a softkey template and assigned to phone.
when i try to dial extension by his 1st digit there is no index displayed ?? and then i press Abbredial key it is displaying me "number not found"
Dear Carlo can you explore more on the below line according to  your previous reply
What he should do is press the number of configured Abbreviated dial number ???? and press AbbrDial softkey on the phone
Hi Clark,
have u created softkey template : Standard User as Abbreviated Dial
In SoftKey Template configuration, have u selected
a. Select a Call State to Configure as OFF-HOOK with select keys as Abbreviated DIal
b. Select A Call State to Configure : Digits after First  with Select Keys as Abbreviated Dial
c. Select a Call State to Configure :OffHook with Feature with Select Keys as Abbreviated Dial
After that have u applied, Standard Softkey template to the desired phone.
please cross-check.
regds,
aman
Because thats no how you use abbr dial, you just need to dial 1 (or whatever abbrdial entry you want to dial) and press the abbrdial softkey.
java
if this helps, please rate
Dears
I have the softkey in place but stilI i am confuse after configuring the speed dial number and assigning the softkey, what i have to do, can naybody brief me,
suppose for example the speed dial number is 5555
  1. ??
  2. ???
  3. ???
  4. ???
  5. ??
Hi Clark,
regds,
aman
Hi.
Carlo
Aman & Carlo,ROB
It is working in either ways
Kudos to Rob, Aman and Carlo.. Appreciate your passion to help everyone in the community. Thanks for sharing your knowledge and educating everyone.
Clark, You can refer this document as well if required.
https://supportforums.cisco.com/docs/DOC-40245
Lavanya
