Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
CUCM Splitting a ISDN E1 Link
Hi there,
I would like to Know if it's possible to split an E1 ISDN Link to PSTN.
For instance lets supouse that two companies are sharing an CUCM and theres only one E1 ISND Link to outgoing calls to PSTN, If I would like to split the e1 isdn channels for example 20 for company A and 10 voice channels for company B, how could I need to manage the interface on CUCM in order to achive this?
Luis Martinez
You cannot do that in CUCM, you would need to do that directly in the GW and you MUST use H323.
We do not support fractional links with MGCP. So in CUCM you just configure 1 H323 GW and the rest is done in the actual GW.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Green
Luis,
I assume that the 2 companies A & B will be set up in CUCM with their own individual
Partitions & CSS etc.
They would also need their own route patterns
They could share the the gateway.
There would need to be a difference in accessing the PSTN
E.g.
COMP A dial 9 for PSTN access
COMP B dial 4 for PSTN access
COMPA EXTN NUMBERS 7xxx
COMPB EXTN NUMBERS 8xxx
Shared H323 Gateway lets say 10.10.10.10
A config along these lines should be OK
hostname VOIP ROUTER
isdn switch-type primary-net5
voice call send-alert
voice call disc-pi-off
voice rtp send-recv
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
voice class h323 1
  h225 timeout tcp establish 3
trunk group COMPA
trunk group COMPB
controller E1 1/0/0
pri-group timeslots 1-31
trunk-group COMPA timeslots 1-21
trunk-group COMPB timeslots 22-31
description *** ISDN for PSTN  ***
interface Serial1/0/0:15
no ip address
encapsulation hdlc
no logging event link-status
isdn overlap-receiving T302 2000
isdn incoming-voice voice
no cdp enable
interface GigabitEthernet0/0
description *** VOIP LAN ***
ip address 10.10.10.10 255.255.255.0
no ip redirects
h323-gateway voip bind srcaddr 10.10.10.10
dial-peer voice 1 pots
description *** FOR INCOMING CALL MATCHING to COMPA ***
incoming called-number 7...
direct-inward-dial
trunkgroup COMPA
dial-peer voice 2 pots
description *** FOR INCOMING CALL MATCHING TO COMPB ***
incoming called-number 8...
direct-inward-dial
trunkgroup COMPB
dial-peer voice 4 pots
description *** O/G LEVEL 4 TRAFFIC TO PSTN COMP B ***
destination-pattern 4T
tone ringback alert-no-PI
progress_ind setup enable 3
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind connect enable 8
direct-inward-dial
trunkgroup COMPB
dial-peer voice 9 pots
description *** O/G LEVEL 4 TRAFFIC TO PSTN COMP A ***
destination-pattern 9T
direct-inward-dial
trunkgroup COMPA
dial-peer voice 11 voip
description *** TO CUCM FOR COMPA ***
preference 1
destination-pattern 7...
incoming called-number .
voice-class codec 1
voice-class h323 1
session target ipv4:10.10.10.200
dtmf-relay h245-alphanumeric
ip qos dscp ef media
ip qos dscp cs3 sig
no vad
dial-peer voice 12 voip
description *** TO CUCM FOR COMPB ***
preference 1
destination-pattern 8...
voice-class codec 1
voice-class h323 1
ip qos dscp cs3 sig
no vad
You would need to adjust this for your own setup
Alex
Regards, Alex. Please rate useful posts.
1491
