CUCM SQL help
I need to extract the phone number(s), MAC Address, IP address  and description of all the phones in the CUCM cluster. I could not find which table these info resides.
Any Idea which table I need to look for these ?..
Thanks in Advance,
Raghu
Everyone's tags (1)
1 ACCEPTED SOLUTION
Hi.Also phoneextn gives you
Hi.
Also phoneextn gives you all dns in risdb with sep
show risdb query phoneextn phone gives you both separately
Carlo
Please rate all helpful posts "The more you help the more you learn"
If I recall correctly, it was
If I recall correctly, it was all in numplan table all the info regarding the DNs and patterns, the IP is in no table in the DB, have you reviewed the data dictionary for your CUCM version??
java
if this helps, please rate
www.cisco.com/go/pdi
Hi.try with show risdb query
Hi.
try with show risdb query phone if it could work for you
regards
Carlo
Hi.
Carlo
This worked but I have to run
This worked but I have to run it on every node..
risdb shows registered phones
risdb shows registered phones on a per node basis.
You can refer to this to extract data from one node for all nodes for registered and un-registered phones,
http://www.cisco.com/c/en/us/support/docs/unified-communications/unified-communications-manager-callmanager/117726-technote-cucm-00.html
I believe IP Address of the phone is seen only in risdb.
VIP Super Bronze
Carlo! Great answer..Wao The
Carlo! Great answer..Wao The RISDB table is very useful!! Just discovered this today..We learn everyday.
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Deji.Thank you my friend!It's
Deji.
It's true and that's why this community is great!
Cheers
Carlo
161
