Community Member
CUCM Standard local route groups QSIG features
Hi guys,
we have a issue with standard local route groups.
Is it possibile, that QSIG-features, like calling name presentation, don't work with standard local route groups?
If i associated a routepattern directly with a Route-Group (the same as the configured in device pools for using standard local route groups), i get the calling name on my pbx. If i use the standard local route group,  the calling name isn't displayed on my pbx phone.
Is it a bug, or works as designed?
any ideas?
Paul
1 REPLY
Community Member
Re: CUCM Standard local route groups QSIG features
Is this "feature" maybe descriped here?
Mixed Route Lists
You cannot insert SIP route groups and Q.SIG route groups into a route list at the same time. With the Local Route Group feature, this mixed route list rule cannot get enforced during provisioning because the binding between the Standard Local Route Group and a provisioned route group occurs dynamically during the call setup. Therefore, some Q.SIG related features may not be available. The binding from Standard Local Route Group to a Q.SIG route group should be avoided.
Is this only, if i mixed it with SIP route groups, or generaly? What else Q.SIG features a disabled?
283
