02-24-2014 02:22 AM - edited 03-16-2019 09:52 PM
Dear Team,
My Subscriber backup got currupt due to virus issue and i need to restore my down cucm subscriber node as phones running thrugh Publisher node.
Please help.
hari
02-24-2014 02:34 AM
Hari,
If your publisher is up, I suggest you just re-install your subscriber using the same credentials, ip address, host name etc..
Please rate all useful posts
"The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
02-24-2014 02:43 AM
HI Aokanlawon.
Thanks.
As per you answer if i will reinstall with same information data would be sync to subscriber from Publisher i dont need to worry.
hari
02-24-2014 02:45 AM
Yes, your subscriber should connect with the publisher without any issues..Check your database replication after you finish installation...When everything is fine, you can then take a new backup
02-24-2014 02:51 AM
Thanks for your quick response on this issue
hari
02-24-2014 03:09 AM
HI Aokanlawon,
still I have one query, the issue belongs to my remote client site and where they have installed the CUCM setup is on VM environment.
Kindly suggest how do i recover in this case.
hari
02-24-2014 03:18 AM
You should install the subcriber the way it was installed orginially on the VM using CUCM OVA templates and the same CUCM version running on the publisher.
02-24-2014 08:13 PM
Thank you very much for your extend support.
hari
