CUCM Switchover
Hi. I have been replacing one CUCM with completely another, with different IP, completely not related with prevoius one. I have replaced 150 option in DHCP pool with this new CUCM IP. Next i issued a "reset" command on old CUCM, all phones rebooted, having new TFTP in settings, BUT continued registering on old CUCM.
I had to walk over 30 workplaces manually resetting all phones to factory setting, and only after that they had registered on new CUCM.
What i did wrong and how to prevent that behavior in future?
BTW: Same procedure for CME worked just fine.
Everyone's tags (1)
1 ACCEPTED SOLUTION
Blue
CUCM Switchover
Please see if below documnet helps you.
https://supportforums.cisco.com/docs/DOC-15799
Ronak patel
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Blue
CUCM Switchover
While this happens, what does your Ip phone shows in following field
1) TFTP Server 1
2) Unified CM 1
Ronak Patel
CUCM Switchover
As i said, phones have correct TFTP 1 setting and INCORRECT CM 1 setting. SEPxxxx.xml.cnf have correct CM inside.
Blue
CUCM Switchover
Ronak patel
CUCM Switchover
Thanks.
333
