Community Member
CUCM System Messages
i have a question about vocal system messages in CUCM 7.1.3. I know that, under "Route Patterns" i can select "block this pattern" and choose the voice message that gives the reason of blocking...but my need is another: can i select system messages without selecting blocking features of pattern ? I explain better: suppose i have 2 CSS containing 2 partitions :
- local_CSS: which includes 1 partition to local numbers (local_PT)
- national_CSS: which includes 2 partitions: the local_PT and the other that contains the national numbers (national_PT)
So if i have a line that has the local_CSS, this line can't dial numbers included in national_PT...so this is my question: how can i select the voice system message that plays after that line attempts to call a number in national_PT  saying that this destination is denied ? I tried to do this and there is a message but i'd like to know if i can select it.
Thank you,
Roberto
1 ACCEPTED SOLUTION
Re: CUCM System Messages
ANN customization is only on 8.X release, there is no method in any previous version
Announcement Configuration
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/8_0_2/ccmcfg/b04announce.html
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
1 REPLY
java
java
272
