CUCM telephone number statistics
Hello.
Is there any report available in which I can see incoming and outcoming calls to/from specific telephone number for 1 hour? Or a day?
Everyone's tags (1)
Silver
Hello,If you are not running
If you are not running any third party call record applications, your best bet would be to comb through the raw CDR data. Running your results based on extension and particular gateway.
Hope this helps,
Tony
Please rate helpful posts
Tony
This is exactly what CDR
This is exactly what CDR provides.
77
