Community Member
CUCM to Cisco Unity Design
Hello
I'm looking to design a CUCM cluster with
1 Publisher
4 Active Subs
4 Back up Subs
2 Dedicated TFTP Servers.
I will have 4 Call Manager Groups as so:
CMG1
sub1 - d-cucm001
sub3 - p-cucm003
sub5 - d-cucm003
CMG2
sub2 - d-cucm002
sub4 - p-cucm004
sub6 - d-cucm004
CMG3
sub7 - p-cucm001
sub5 - d-cucm003
sub3 - p-cucm003
CMG4
sub8 - p-cucm002
sub6 - d-cucm004
sub4 - p-cucm004
For Cisco Unity Connection:
1 Publisher
1 Secondary
I will have one pilot number for voicemail.
I will be utilizing 96 VM ports on each Unity Connection box.
How many port groups should I configure on the Cisco Unity Connection?
Also how should my CUCM servers be set up within the port groups?
Thank You
My assumption is that you have a CUC cluster (based on your info above).  If you are only integrating with this CUCM cluster, then you would just set up 2 port groups - 1 per CUC server.
Hailey
Please rate helpful posts!
Community Member
Yep, the CUC is setup as a cluster.
Yep, I'm just integrating with this one CUCM cluster.
What would be the best way to setup the 2 port groups, as far as CUCM's go?
How many device pools do I need to configure on the CUCM for these voice mail ports.
Thank You!
Hall of Fame Super Silver
Is the cluster split between 2 data centers? If 2 data centers I would consider 2 separate pilots to have control of which server is used by which users and build load balancing.
I personally like to use 2 Groups per UCON Server and split it between separate CUCM groups, this way if one of the primary CUCM server goes down not all ports have to re-register at the same time, but if all servers are at the same data center this would be an overkill.
Chris
Community Member
So the requirement on my side is to only have one hunt pilot.
The primary CUC server sits in data center "D" and the  secondary CUC server sits in data center "P".  Both are located on the  same campus though.
So if on the CUCM side I only  created one device pool to put these CUC servers on, what would happen  if all three call managers in my CMG that the device pool points to were  to go down?
Would it be better to create two device pools, one for each CUC?
On the CUC side, two port groups are sufficient?  One for the PUB and one for the SUB?
I  was told that for the Call Managers I configure in the port groups, I  should match them to the Call Manager Groups in CUCM, is this correct?
Looking at how I have my Call Manager Groups in CUCM, which would be the best group to choose?
CMG1
sub1 - d-cucm001
sub3 - p-cucm003
sub5 - d-cucm003
CMG2
sub2 - d-cucm002
sub4 - p-cucm004
sub6 - d-cucm004
CMG3
sub7 - p-cucm001
sub5 - d-cucm003
sub3 - p-cucm003
CMG4
sub8 - p-cucm002
sub6 - d-cucm004
sub4 - p-cucm004
d = data center 1
p = data center 2
Thank You
Re: CUCM to Cisco Unity Design
I would create at least 2 device pools. For example: Primary CUC assigned to device pool for media devices in data center "D", Secondary CUC assigned to device pool for media devices in data center "P"
The CM group and assignment may have other considerations for you...such as how you're trying to distribute devices across CM's, failover and tertiary failover considerations, and etc. I would want the Primary CUC ports to register to a subscriber in the same data center (i.e., D). The same would be true of the Secondary CUC ports (i.e., P).
IMO, 2 port groups are fine - 1 for each server. Assign the servers based on your CM group selection.
Hailey
It really depends on the physical location of the servers as far as the device pools go.  Let's say you have 1 server in Site1 and the other in Site2.  In that case, I would generally have a device pool at each site for media / applications:
CUC Primary at Site1 would be in Site1_Media_DP
CUC Secondary at Site 2 would be in Site2_Media_DP
In CUCM, I would have 2 line groups - one for the CUC Publisher and one for the CUC Subscriber with a single hunt list.  The priority of the line groups would be:
CUC-Sub_LG
CUC-Pub_LG
In a Unity Connection cluster, you want the Subscriber to be the primary call processor and then you can overflow to the Publisher ports (if required) during peak call volumes.  Just remember that if you have ports that are solely dedicated to MWI (i.e., they do not answer calls...then do not add them those ports to the CUCM line groups).
Hailey
395
