Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
CUCM: tomcat use most of the memory
Hello!
CUCM 6.1(1) running on MCS7825H3-K9-CMA2.
The problem is:
admin:show process load memory
15:29:46 up 82 days, 6:07, 1 user, load average: 0.13, 0.16, 0.17
132 processes: 131 sleeping, 1 running, 0 zombie, 0 stopped
CPU states: cpu user nice system irq softirq iowait idle
total 0.4% 0.0% 0.0% 0.0% 0.9% 0.0% 98.5%
cpu00 0.0% 0.0% 0.0% 0.0% 0.9% 0.0% 99.0%
cpu01 0.9% 0.0% 0.0% 0.0% 0.9% 0.0% 98.0%
Mem: 2053864k av, 2034240k used, 19624k free, 0k shrd, 82080k buff
1244884k actv, 332464k in_d, 32208k in_c
Swap: 2048248k av, 987544k used, 1060704k free 835800k cached
PID USER PRI NI SIZE RSS SHARE STAT %CPU %MEM TIME CPU COMMAND
28642 tomcat 17 0 277M 254M 7924 S 0.4 12.6 611:20 0 tomcat
24467 ccmbase 15 0 133M 133M 67576 S 0.0 6.6 3:33 1 ccm
8149 informix 15 0 133M 132M 132M S 0.0 6.6 2842m 1 cmoninit
11119 ccmservi 22 0 147M 66M 4624 S 0.0 3.3 606:22 0 amc
11648 ccmservi 15 0 111M 57M 3600 S 0.0 2.8 65:48 1 rtmtreporter
11116 ccmservi 16 0 48944 38M 13872 S 0.0 1.9 1759m 1 RisDC
11194 ccmservi 16 0 170M 37M 3652 S 0.0 1.8 1376m 1 carschlr
6242 Administ 25 10 27576 26M 10064 S N 0.0 1.3 0:01 0 java
15291 ccmservi 15 0 35756 25M 10572 S 0.0 1.2 309:26 0 CTIManager
10594 licmgr 24 0 90524 24M 4708 S 0.0 1.1 61:59 0 CiscoLicenseM
admin:
What i can do to decrease using memory?
Should i increse the onboard memory from 2Gb to 4Gb?
Pls, advice me.
Re: CUCM: tomcat use most of the memory
Hi volkovvalery,
I also faced same problem. I restarted the CCM cluster. After that this reduce. This one bug in Call Manager. Or u can restart the tomcat service also.
I m not thinking u wanted to add more memory.
If u using the RTMT there also u can see this problem, there u can see Virtual Memory and swap memory also increased.
For this matter pls refer Cisco site and install latest service patches.
Sunish
Hi sunishnair, thanks for your reply.
I'm restarting the tomcat service (and ccm service) any times, but in a few days the same condition happening again.
Can i directly update cucm 6.1(1) to 6.1(2), and after this install 6.1(2)SU1a?
can you please check with release notes for 6.1(2)after that you can upload the new service release for this particular problem.
Sunish
818
