Community Member
CUCM - Trace
Hi All ,
I read through the CCM SDI logs. Just want to know some info on CCM traces on acadamic purposes.
Below lines are from sdi traces of SIP trunk call.
23:30:57.392 |DET-MediaExchange-(95)::fillAudioMediaInfo, partyIdx=0, xferMode=16, codec=15, maxFramesPerPacket=30i, sRTP=0, mediaSecurity=1|1,100,56,1.942973^^SEP001EF7C2AD14
23:30:57.392 |DET-MediaExchange-(95)::fillAudioMediaInfo, partyIdx=1, xferMode=4, codec=15, maxFramesPerPacket=20i, sRTP=0, mediaSecurity=1|1,100,56,1.942973^^SEP001EF7C2AD14
xferMode - What is mean ?
3:30:57.367 |SIG-MediaManager-(69)::wait_AuConnectRequest, CI(32286197,32286198), capCount(6,8), mcNodeId(0,0), xferMode(16,4), reConnectType(0), mrid (0, 0) IFCreated(0 0) proIns(0 0), AC(0,0) party1DTMF(3 2 101 1 0) party2DTMF(1 3 0 0 0),reConnFlag=0, connType(3,3), IFHand(0,0),MTP(0,0),MRGL(,32952426-29c5-555e-50ef-56bd743e2fb0) videoCap(0 0), mmCallType(0),FS(0,0) IpAddrMode(0 0) aPid(1, 74, 701), bPid(1, 57, 38) EOType(2 0) MohAnnConnType(0 0)|1,100,56,1.942972^10.228.193.166^SEP001EF7C2AD14
3 2 101 1 0 -- What is meaning of these values ? . 101 - DTMF Payload .
Thanks in Advance ...
CUCM - Trace
I don't know what xferMode means since I've never used it's value for any trace reading or problem solving that I can remember.  The party1DTMF mode values indicate, prefer2833 which is the DTMF preference, then 2833 indicating support for 2833 only, followed by the 2833 payload type, followed by 1 which means True that the endpoint wants DTMF reception.
Hi  // Transfer modeconst
Xfer Mode 16 :- must be for the SIP.
Xfer Mode basically tells method of telling other CCM subsystems what types of
devices the RTP audio connection is between.
For Example :- 3 is for H323_MODE , 4 for Agena , 7 for H323
I hope this helps
Abhay Singh Reyal
Abhay Singh Reyal
The Only Way To Do Great Work Is To Love What You Do. If You Haven’t Found It Yet, Keep Looking. Don’t Settle
Community Member
Hello,I cannot remember these
I cannot remember these values from the top of my head. But these values can be given to you in detail if you ask a TAC engineer.
xFermode refers to the phone protocol type. If I recollect right, 4 is Agena (SCCP Phone).
Party1DTMF( 3 2 101 1 0) --> crucial values are black, red, green
BLACK: The preferred dtmf method --> 3 --> RFC2833 + OOB
RED: The supported DTMF method --> 2 --> RFC2833
GREEN: The DTMF RTP Payload in case we support in band DTMF. --> 101 -->RFC 2833 Payload 101
party2DTMF: 1 --> OOB .. 3 --> RFC2833+OOB, 0 --> No in band DTMF specific payload
The preferred DTMF method generally takes values from the Preferred DTMF check box in SIP Trunk --> i.e. No Preference, RFC2833 (101 payload), RFC2833 + OOB
Please rate useful posts!
~Avinash
962
