Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
CUCM transcoding. DSP farm adds to or replaces software DSP ?
I have a CUCM 6.1. My understanding is that this has 48 MTP sessions running in software?. If I connect the CUCM to an external DSP farm will the resources available on the farm be added to the existing MTP resources or replace them? Thanks.
1 ACCEPTED SOLUTION
Re: CUCM transcoding. DSP farm adds to or replaces software DSP
You'll need to configure the MTP or XCODER into the MRG for devices to use it.
But you can configure SW MTP + HW to get a total of X sessions
java
if this helps, please rate
java
www.cisco.com/go/pdi
1 REPLY
java
java
339
