CUCM Translation Pattern Help required
Hi All,
I am using CUCM 8.5. I have a block of number from 67030000 to 67030999. For all this numbers called via PSTN the call should land on 67030000(reception). For the numbers 67030300 and 67030400 the call should land on two different locations. The translation pattern for 67030300 and 67030400 I have created and the calls are successfully landing on the other locations. But for other numbers the translations are not happening.
Thanks & Regards,
Fawaz
Green
Re: CUCM Translation Pattern Help required
The transdlation pattern 67030XXX
Called Party transform mask 67030000
Your other 2 patterns should be configured as full digit pattens 67030300 & 67030400
Alex
Regards, Alex. Please rate useful posts.
This is the translation pattern i have created for 67030300.
Translation Pattern: 30300
Partition:PSTN-INTERNAL
CSS:PSTN-INTERNATIONAL
Calling Party Transform Mask:67030300
Prefix Digits:9
Called Party Transform Mask:0015126021000#
Prefix Digits:9
This is the sample translation pattern I have created for other numbers.
Translation Pattern: 300XX
Calling Party Transform Mask:670303XX
Prefix Digits:9
Called Party Transform Mask:30000
According to the 2nd translation pattern configuration, when i call on 67030022 the call call should land on 67030000. But instead the call is landing on 67030022.
Green
I agree with you.
Your 2nd pattern should derive 30000
I think you need to use the Dial Number Analyser and see what is going on.
Alex
Yes  the second pattern should drive 30000. But it is not happening. The DNA test is done and below is the result for the second pattern.
  • Results Summary
  • Calling Party Information
    • Calling Party = 30022
    • Partition =
    • Device CSS =
    • Line CSS =
    • AAR Group Name =
    • AAR CSS =
  • Dialed Digits = 30066
  • Match Result = BlockThisPattern
  • Route Block Cause = Unallocated Number
  • Called Party Number =
  • Matched Pattern Information
    • Pattern =
    • Partition =
  • Pattern Type =
  • Time Zone =
  • Outside Dial Tone = NO
  • Call Flow
    • TranslationPattern :Pattern=
      • Partition =
      • Positional Match List =
      • Calling Party Number = 30022
      • PreTransform Calling Party Number =
      • PreTransform Called Party Number =
      • Calling Party Transformations
        • External Phone Number Mask = NO
        • Calling Party Mask =
        • Prefix =
        • CallingLineId Presentation =
        • CallingName Presentation =
      • ConnectedParty Transformations
        • ConnectedLineId Presentation =
        • ConnectedName Presentation =
      • Called Party Transformations
        • Called Party Mask =
        • Discard Digits Instruction =
        • Prefix =
        • Called Number =
  • Alternate Matches
    • Note: Information Not Available
Green
What number are you dialling ?
According to your result it was 30066
Alex
What ever the number may be as far as my translation pattern is 300XX, all the dialed numbers from 30000 to 30099 the call should land on 30000. Which is not happening.
Green
Can you delete the TP 300XX
Can you then search for DNs starting 300 in the route plan
Alex
The TP 300XX is deleted. I searched for the DNs starting 300 in the route plan. I got 47 results on that.
Fawaz
Green
Are any of these 47 other TPs that would match 30066 for example
Alex
No. I have only two TPs right now in CUCM. One is 30300 and 30400.
Green
Lets add a simple TP with only these settings.
Pattern 300XX
Partition INTERNAL
Test this from a INTERNAL (Partition) phone
Then the gateway
Alex
That is done. The same result. The number is not getting translated. I created a TP 300XX. and called party Transform mask: 30000.
I tested internally. I called 30066, the call is landing on 30066.
I tested using pstn. Used my handphone. again the call is landing on 30066.
Fawaz
Adding the DNA test of the above said TP configuration
  • Results Summary
    • Partition =
    • Device CSS =
    • Line CSS = CSS-PSTN-International
    • AAR Group Name =
    • AAR CSS =
  • Match Result = RouteThisPattern
    • Pattern = 30066
    • Partition = PT-PSTN-Internal
    • Time Schedule =
  • Called Party Number = 30066
  • Time Zone = Etc/GMT
  • Call Classification = OnNet
  • InterDigit Timeout = NO
  • Device Override = Disabled
  • Call Flow
    • Partition =
    • Positional Match List = 30066
      • Prefix =
      • Prefix =
      • Called Number =
  • Directory Number :DN= 30066
    • TypeCFACSSPolicy =
    • Call Classification = Unknown
    • Forwarding Information
      • Forward All : DN = VoiceMail = No CSS =
      • Forward Busy
        • Internal : DN = 30000 VoiceMail = No CSS = CSS-PSTN-Internal
        • External : DN = 30000 VoiceMail = No CSS = CSS-PSTN-Internal
      • Forward No Answer
      • Forward No Coverage
      • Forward Unregistered
      • CFDF : DN = 30000 VoiceMail = No CSS = CSS-PSTN-Internal
      • Pickup Group Number =
    • Device :Type= Cisco 8961
      • Device Status = Registered
      • Device Name = SEP08D09F9EB4AD
      • Ignore Presentation Indicators = Disabled
      • Logged Into Hunt Groups = Enabled
      • Alerting Name = Sivalingam Sellappan
      • Dual Mode = Disabled
      • Do Not Disturb(DND)
        • DND Status = Disabled
        • DND Option =
        • DND Incoming Call Alert =
      • Automated Alternate Routing (AAR)
        • AAR Group Name =
        • AAR Calling Search Space =
        • AAR VoiceMail Status = Disabled
        • AAR Destination Mask =
        • AAR Prefix Digits =
  • Alternate Matches
  • Partition :Name= PT-PSTN-Internal
    • Pattern
      • Pattern = 300XX
      • Pattern Type = Translation
      • TranslationPartition = [cd70125a-8e98-3209-62f2-122212116844]
      • CallManager Device Type = AccessDevice
      • PatternPrecedenceLevel = PlDefault
      • PatternRouteClass = RouteClassDefault
      • RouteNextHopByCgpn = false
Green
This is because 30066 is defined as a phone line DN
Can you test again with a spare 300XX number.
Alex
Yes, I dialed a spare number 30012. Now it is landing on 30000.
Fawaz
I used PSTN to call 30012 and it is now landing on 30000 as required. That means all the unassigned numbers would land on 30000 and the assigned numbers will land on the respective phones. So what to do now for all the assigned DNs? I mean around 250 numbers has been assigned as of now. So is there any solution for this?
Fawaz
Green
Is your requirement to stop individual DID/DDI from the PSTN to all your phones ?
So all DID/DDI numbers will all route to 30000
If this is the case.
If you are using H323/PRI gateways or SIP/PRI
you could invoke a PLAR on the Voice port to 30000.
Alex
Yes my requirement is to route all the DID to the board number 30000. Except 30300 and 30400.
I am using a MGCP gateway.
Fawaz
Green
Fawaz,
This can be acheived with MGCP but it has to be carried ot on the CUCM not the IOS gateway.
1) Create a new partition like PT-PSTN-INCOME
2) Move or create new Translation patterns similar to what we know works and use the new partition.
Make sure they have a CSS that can find the destination you want like 300000 and yor 0015126021000# DN
3) Create a new CSS like CSS-PSTN-INCOME
Only put the new patition in this new CSS
4) Change the CSS of the incoming MGCP gatewat to CSS-PSTN-INCOME
Thisd new CSS & PARTITION must be private just to your PSTN gateways
Make sure you an revert if you have trouble
Alex
Hi Alex,
Its not working. I tried it but still the call lamds on the dialed number. The number which is already assigned is not getting translated. The free numbers are getting translated. Any other way to do this?
Fawaz
7801
