CUCM - trunking between 7 and 9
Document needed to do a trunking between cucm 7 and cucm 9  ( intercluster trunking)
We are planning to route a PSTN call from IP phones which are registerd with old CUCM on version 7 from our new cucm 9 which has FXO- line active.
how do I achive it.
HelloYou have to use
Hello
You have to use intercluster non-gatekeeper controlled . I do nothink there is special document for this , but you can see the below link:-
https://supportforums.cisco.com/discussion/11766291/intercluster-sip-trunk-between-cucm-version-71-and-91
please rate all useful ifnromation
Other than the ICT to connect
Other than the ICT to connect the two clusters, it all comes down to call routing, route pattern, partitions and CSS, nothing else. Route the call from 7 to 9 via ICT, and make sure you can reach the FXO on 9.
java
if this helps, please rate
www.cisco.com/go/pdi
31
