Community Member
CUCM/Unity 9.1.2 LDAP integration
I'm getting the following error when trying Perform Full Sync Now;under LDAP Directories;
Failed to connect to ldap://10.1.3.17:3268, check the server IP address or the network connection
We tried to reset the password, restarted Cisco Directory sync service.
I also followed the steps outlined in a youtube video, https://www.youtube.com/watch?v=1gTpkkSmdIM
If anyone has encountered this issue or could suggest any troubleshooting steps please advise.
AK
Was this working before?Are
Are you sure you're using the  right credentials/user? and you're writing this in the proper format??
java
if this helps, please rate
www.cisco.com/go/pdi
Community Member
Hi, Use the LDAP Port number
Use the LDAP Port number as 389 instead of 3268 and Try.
regards
Ram
178
