CUCM, Unity Cnx and IPCC Express TLS version
Does anyone know what TLS versions are supported by CUCM, Unity Cnx, Contact Centre Express/Enterprise, eg TLS1, 1.1, etc.  How do I verify this on the platform?
If they support TLS 1.1 is it possible to disable early versions of the protocol to prevent them from being used, ie TLS 1.0?
Cheers
1 ACCEPTED SOLUTION
I found a bug for this: CSCtt13316    TLS 1.1 and TLS 1.2 support
Please refer to this link for details:
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCtt13316
Tere.
If you find this post helpful, please rate!
Regards, Tere. If you find this post helpful, please rate! :)
AFAIK TLS v1 for all ver of CUCM and there is no method to disable or enable TLS version on it.You can use the command "show web-security" on the CLI and check what TLS version you have. The same should apply to CUC.
Tere.
Hi Tere,
Thanks for the info...Heres the show web-security output - I guess the '1' is the TLS version?
admin:show web-security
Certificate:
Data:         Version: 1 (0x0)
Do you know if there are any plans to introduce TLS 1.1 or higher.  I have a recent PenTest report from one of my clients indicating medium level threats assosiated with TLS 1.0 and man-in-the-middle attatcks.
Steve
Tere.
Hi Tere,
Thanks very much for looking in to this.......I'll pass on the info.  Cheers Steve
1287
