CUCM &Unity Connection ports
Dear,
I have a unity connection setup in which publisher is in HO and the subscriber is in DR, i want to know the port list for communication between the unity connection pub and sub and in between unity and cucm,
As per the link below, i managed to get the port list for CUCM and IM& Presence  but there is no information for the ports between unity connection and CUCM.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/port/9_1_1/CUCM_BK_T2CA6EDE_00_tcp-port-usage-guide-91.html
1 ACCEPTED SOLUTION
VIP Purple
Hi, you can refer the link
you can refer the link for UCXN 9
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/9x/security/guide/9xcucsecx/9xcucsec010.html
regds,
aman
VIP Purple
regds,
aman
Dear Aman1 question
Dear Aman
1 question,
subscriber usually takes the time from publisher,suppose when the publisher fails then, subscriber takes the time from where???
VIP Purple
Hi,I have never tested this
I have never tested this but what I think that Subscriber would switch over to its local clock.
NTP is configurable only in PUB
redgs,
aman
Dear Aman, We set the country
Dear Aman,
We set the country while installing we dont set any local time,???
59
