CUCM - Unity - Presence - 7.1.3 - with ESX
Hi there,
I know that CUCM, Unity-Connection and Presence are only supported with the version 8.x &+
But,
Lets say, I have my production that run on MCS server at 7.1.3  and I want to do re-install on a UCS Server.
I would like to install 7.1.3 on the UCS and restore all backup to it then upgrade to 8.x
Is it possible ?  Is it supported ?
...somebody told me that there is maybe the upgrade is supported ( the time you go from 7.1.3 to 8.x )  but running 7.1.3 for production is not support
anyone ?
thanks
  • IP Telephony
1 ACCEPTED SOLUTION
No, that's not supported.
The supported method is to upgrade on MCS up to AT LEAST the first release for each product supported on VM, do a backup and then restore on UCS.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
1 REPLY
java
java
149
