CUCM & Unity Upgrade - at same time ?
PC PC
Hi Guys, I was Wonder if it is possible to upgrade CUCM 8.6 and Unity 8.6 at same time ( To 9.1.2 ) ex : I Upgrade my CUCM PUB AND Unity PUB At SAME time. So both process the upgrade file at same time. Then, I Reboot CUCM PUB Only ( from what I saw, we have to reboot Unity once the cluster is update.. not the case for CUCM ) And again at same time : I Update CUCM SUB I Update Unity SUB
Jaime Valencia
Yes, assuming you have redundancy, or don't care about service interruption if you don't have it, there's no problem.
java
if this helps, please rate
Jaime Valencia
java
PC PC
Can you confirm....
We will Update CUCM PUB,
Reload CUCM PUB
We will Update CUCM SUB
Reload CUCM SUB
We will Update Unity PUB
We will Update Unity SUB
Once both are update,
We reload PUB
Then
We reload SUB
