CUCM Unrestricted Software and IP Phone SSL VPN
I need to know whether CUCM 8.x clusters running Unrestricted versions of CUCM can support phones using the IP Phone AnyConnect SSL VPN feature.
The release notes - see below - state that "Signaling and media encryption is permanently disabled in the unrestricted version"
So I guess that the SSL VPN will not work? - can anyone confirm this to be the case?
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/7_1_5/cucm-rel_notes-715.html#wp1768767
Everyone's tags (3)
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Hi James,
The newer versions of the Security guide do show this caveat/restriction
Note The VPN menu and its options are not available in the U.S. export unrestricted version of Cisco Unified Communications Manager.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/security/8_6_1/secugd/secuvpn.html
Cheers!
Rob
Hi James,
Cheers!
Rob
Hi Rob,
Thanks for confirming this.
I guess that I will be rebuilding a CUCM cluster
648
