CUCM UPGRADATION 8.6 to 10.0
Hi Guys,
I am plan to upgrade the call manager from the version 8.6 to 10.0.,while upgradating from 8.6 can i directly upgradte to 10.0? should i need to order any Migration Licenses?
Advice me on this upgradation
Advice me on this upgradation steps
VIP Gold
You can refer below upgrade
You can refer below upgrade guide, it will help you to plan perfectly.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/upgrade/10_0_1/CUCM_BK_U4214F9D_00_upgrade-guide-cucm-100.html
You need to request the license via Product Upgrade Tool, you need to get converted DLUs to UCL/CUWL from Cisco as per your requirement, license structure has changed in 9.x and later.
CUCM 10.0 and beyond is only supported in a virtualized deployment so you need to take care of it.
Suresh
Dear Suresh,Thanks for your
Dear Suresh,
Thanks for your information,
Its already in a Virtual deployement,we dont have the subscription for ucss.
VIP Purple
Hi Siva, If you do not have
Hi Siva,
If you do not have the UCSS, then ,, u need to contact Partner who could provide u with BoQ for migration.
regds,
aman
Hi Aman, Thanks fo the info.
Hi Aman,
Thanks fo the info.
VIP Purple
Hi Siva, Basically, PCD is an
Hi Siva,
Basically, PCD is an pplication used for migration of legacy CUCM clusters version 6.1.5, 7.1.5 , 8.x to new VM based servers.Also, to change IP address on CUCM 10, switch versions,reboot and install COP files.
In your case, u can upgrade to 10 even without PCD. Just need to check the compatibility matrix.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/compat/matrix/10_x/CUCM_BK_CD1DB914_00_compat_matrix.html
regds,
aman
Hello1-As mr/Aman , you will
Hello
1-As mr/Aman , you will need to purchase UCSS for 1 or 3 years up to youfrom one of the Cisco parteners resellers , which allow you to do upgrade ,then you can purchase as optional ESW which is useful to contact TAC for any upgrade Bugs .After that we can do convert from DLU to UCL via the product upgrade tool (PUT). Keep in your mind 6 DLUs converted to 1 X UCL.
please rate all useful infromation
Thanks for the valuable
Thanks for the valuable information.
Dear Islam,Should i required
Dear Islam,
Should i required PCD for this upgradation?
HelloI have a question , the
Hello
I have a question , the upgrade will be for only CUCM or CUC , CUCX?.
You have the both ways "UCSS or PCD" // "where PCD do not need for licesnes" .PCD is a special feature for  V10.X  .
1-The PCD SW & ova should be shipped along with the CUCM 10.x bootable image.You should be able to find the OVA in www.cisco.com downloads section using the following path.
or
2-Downloads Home > Products > Unified Communications > Call Control > Cisco Unified Communications Manager (CallManager) > Cisco Unified Communications Manager Version 10.0 > Unified Communications Manager Virtual Machine Templates-10.0(1).
please rate all useful information
Hello Kindly check the below
Hello
Kindly check the below link which is very useful . The below link includes also Video
https://supportforums.cisco.com/blog/12108306/cisco-unified-communication-manager-cucm-10x
Dear kamal,The upgradation is
Dear kamal,
The upgradation is for CUCM,UC,CWMS,CUCX.
Hello That means that you
Hello
 PCD used for CUCM doesnt support CUC and UCCX migration at the moment .Just FYI
PCD used for migrate from  VM to VM ,and it comes with v 10.x.Direct Migration from "6.1(5),7.1(3)/7.1(5),8.0(1-3),8.6(1-2),9.x TO v10.0+".migration support "A-old IP/Hostname for all cluster nodes", "B-Changing IP .hostname for one or more nodes".
You also need to review the
You also need to review the RNs and new and changed documentation prior to any actual work on the servers.
You can also consider PCD
java
if this helps, please rate
www.cisco.com/go/pdi
Dear Jaime,Thanks for your
Dear Jaime,
Thanks for your mail,
Is it necessary to considerd the PCD?
211
