CUCM Upgrade 6.0 to 6.1
ThomasBond_2
I need to upgrade the Cisco Call Manager version 6.0.1 to the release 6.1.2, this upgrade is direct?
6 Replies 6
Jaime Valencia
No, you need 6.0(1a)
Table 13     Supported Cisco Unified Communications Manager Upgrades for  Release 6.1(2x)
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr.html#wp92373
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Thanks Java
But I was reading the document, and it appears to go up to version 6.1.2.1000-13 from release 6.0.1.3000-7, can be done directly.
Version:              6.1(2) 6.1.2.1000-13
Direct upgrade:  6.0(1b) 6.0.1.3000-7
OK, then you can upgrade directly. We only go by whatever information you provide, in your original post you ask " version 6.0.1 to the release  6.1.2"
To avoid this you need to provide the right information.
java
java
Excuse me, you have absolutely right, I made the mistake, to give little information. The upgrade is from the release 6.0.1.3000-7 to 6.1.2.1000-13.
Thanks Java !
Java, Are the files needed for the upgrade are the following: ¿?
Release  6.1(2)
Filename  UCSInstall_UCOS_6.1.2.1000-13.sgn.iso_part2of2
Release Date  06/May/2008
Description  Cisco Unified Communications Manager 6.1(2) part 2 of 2 (non-bootable) - For upgrade from 6.0(1)
Release  6.1(2)
Filename  UCSInstall_UCOS_6.1.2.1000-13.sgn.iso_part1of2
Description  Cisco Unified Communications Manager 6.1(2) part 1 of 2 (non-bootable) - For upgrade from 6.0(1)
Can you confirm me please?
Thanks Java !
Rob Huffman
Hi Thomas,
Those are the correct files
Upgrading from Cisco Unified Communications Manager Release 6.0.(1a) or higher to Release 6.1(2) by Using the UCSInstall File
Because of its size, the UCSInstall iso file, UCOS_6.1.2.1000-13.sgn.iso, comprises two parts:
Procedure
Step 1 From www.cisco.com, download the two UCSInstall files.
Step 2 Execute one of the following commands to reunite the two parts of the file.
Note Because the 6.1.2.1000-13 build is a nonbootable ISO, it proves useful only for upgrades. You cannot use it for new installations.
a. If you have a Unix/Linux system, cut and paste the following command from this document into the CLI to combine the two parts:
cat UCSInstall_UCOS_6.1.2.1000-13.sgn.iso_part1of2 UCSInstall_UCOS_6.1.2.1000-13.sgn.iso_part2of2 > UCSInstall_UCOS_6.1.2.1000-13.sgn.iso
b. If you have a Windows system, cut and paste the following command from this document into the command prompt (cmd.exe) to combine the two parts:
COPY /B UCSInstall_UCOS_6.1.2.1000-13.sgn.iso_part1of2+UCSInstall_UCOS_6.1.2.1000-13.sgn.iso_part2of2 UCSInstall_UCOS_6.1.2.1000-13.sgn.iso
Step 3 Use an md5sum utility to verify that the MD5 sum of the final file is correct.
68e99f0b080298d65b4b82a8befbfe8b UCSInstall_UCOS_6.1.2.1000-13.sgn.iso
Software Download URLs
You can access the latest software upgrades for Cisco Unified Communications Manager at http://tools.cisco.com/support/downloads/go/Redirect.x?mdfid=278875240
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/6_1_2/cucm-rel_note-612.html#wp442435
Cheers!
Rob
